Woow, you brought it up to the next level. Great job!. ![]()
FWIW, we also found another feature/bug depending on your pov: usually the master reports the average soc of the pack, so with soc of 80,82,78 and 70, the master would report 310/4=77 or 78 depending on rounding.
One particular firmware on the master would report the lowest soc during charging, and the highest during discharge (or the other way around, my memory is fading) . This is fine with a pack where the std dev of the soc is low, i.e. under 2%, but if your pack is as described above, when solar incoming is approximately equal to demand, so the pack is frequently changing from charging to discharging and back again, the soc appears to oscillate between 70 and 82 - verybl disconcerting for the owner
Hi there ![]()
Just want to inform you that newest firmware for MultiPlus II - v555 dramatically improved performance on first site, and on other two completely fixed a problem. On first one the worst seen power factor on genset output is 0.98 lagging and it rarely appears (the vast majority of the time, power factor is 1), but the genset is pretty much stable and there is no need to use weak AC input anymore.
