Hi there,is ist possible to change the battery discharge current regardless if grid is connected?
Thanks,Frank
PS this refers to FW upgrade 1.9
You can use the ESS Limit Inverter Power setting:
This is not possible yet on the Multi RS. The features of VE bus are being slowly rolled out to the RS range.
Thanks,remaims for now a future request ![]()
As an owner of one… Definitely ![]()
Proud owner
