Hi, I’d like to confirm the following diagram showing block fuses mounted on batteries in a parallel way to prevent fire if there ever is a battery fault like internal short (12V system 200Ah total).
Blocks mounted directly onto batteries’ posts. Fuse side of the blocks wired in parallel with proper gauge wire.
I’m not using buss bars since I only got two batteries 100Ah each.
Thanks !
