Tengo una instalación aislada donde desde hace unos días el Smart solar MPPT VE Can 250/100 ha dejado de funcionar. Tiene tensión de batería y de placas pero no vuelca energía en las baterías (BYD Litio). Si os dais cuenta la tensión de batería que mide el MPPT ( 56.50v) es mucho mas alta que la que se mide en el inversor (51.96V), con lo cual estaría por encima de la tensión de absorción claro. Alguien ha tenido un caso similar?? Está actualizado a la ultima versión y lo he reseteado pero sigue igual..
I can’t be sure because I’m not at the installation right now, but I’ve noticed that the Quatro and the BMS are measuring the same, while the MPPT is measuring 4.4V higher.
A physical verification is definitely needed unfortunately. Nothing can be done remotely to troubleshoot (only see there is a problem as you have noted)
I’m sharing the diagnosis and solution to the problem so the entire Victron community can access the information and my experience.
I finally managed to schedule a day for the owner to carry out the checks you indicated, with my remote assistance.
When removing the cabinet covers to check the fuses and measure the battery voltage on the SMART SOLAR, we observed that one of the negative battery cable terminals had overheated.
Once the connections were corrected and all the battery and panel wiring was checked, the Smart Solar is working correctly.
You were absolutely right, @lxonline! “A physical verification is definitely needed.”
