Is that going to work with the near-real-time requirements ?
Well, Iāve used it for phase synchronisation of ac-drives without problems.
As long as you stay local its not a problem.
Whatās the drive frequency?
I would imagine that running a full IP stack would put a lot more pressure on the CPU?
10-100Hz
But Iām only talking about the bus, not the cpu.
Do you know what type SPD? I assume a basic 2 or 3? External type 1 is about Ā£250 each x 7 Ā£! And a lot of work and wall space after 7 isolatorsā¦
I am wondering how you can identify, if itās the updated or the old version of 450/x00 MC4, BEFORE buying?
Is there a specific number or manufacturing date which can be checked and the dealer can be asked for?
The serial is in form of HQXXYYā¦
XX year, YY week
I suppose that those should be as recent as possible, as the technical bulletin is from August 2024, so 3-5 months after that, as they say in the bulletin.
So better be of year 2025.
Since all RS450 models where sold out for over 3 months no one should have any of the old units on stock.
New units should have a serial number from late 24 or early 25.
Even if you some how get an āoldā unit you would be totally fine with that as long as you install it as described in the manual.
The āproblemā was that some users installed the units in a corrosive atmosphere which isnāt allowed.
Victron improved the coating of the PCB.
