I want to elaborate a bit on my question, because I now noticed that my situation is not unique at all because I need the exact same thing now for a very common use-case.
Assume a setup where the whole house is on AC Out. The next 3 days I will not be able to cover my full energy use from solar. In Belgium however it’s important to manage your peak power, so I want the system to peak shave and I need to be sure I keep enough energy in the battery to do that.
Remember that I can’t use the peak shave feature because that works per phase instead of on the sum of all phases and I can’t use it anyway because it requires an external grid meter and I must use the CT clamps.
Default I have the grid setpoint at 50W, but if I keep that setting I will at some point run out of battery and can no longer peak shave.
So I would like to set the grid setpoint higher, ultimately worst case at the peak power. This means anything below that power I will use grid and above the battery helps out.
But any time my house requires less than the grid setpoint the battery starts charging from the grid, which I don’t want.
My intended behaviour is identical as before:
If excess power from solar → charge battery
Between 0W and Setpoint demand (after solar fully used)-> Use only what’s needed from grid, don’t charge
Above Setpoint demand (after solar fully used) → use battery to peak shave
My special use case was fairly easy to automate, because I just need to detect when the (pretty constant) load starts/stops (not frequent at all). This use case (which I assume everyone faces at some point) is much more dynamic and more difficult to manage via e.g. Node Red.
Again: the only thing I need is a “don’t charge from grid” setting, but I don’t think it exists.
PS: If whatever needs to be changed is Open Source and I can just add this feature myself, I am more than happy to do this if someone can point me in the right direction.
