Modbus sensor data to VRM portal
Can someone please share a simple example for this task?
I have a pressure sensor with TCP Modbus output on the same network with multiplus II GX.
How can I read data form sensor and display it in VRM portal?
Thank you.
If you have a GX device, you can easily do the TCP Modbus read with Node Red. A Virtual Device node creates the display portion on the GX GUI and VRM. Use a Custom Control node to feed the read data to your virtual device. I have not verified VRM, but it works on the GX GUI.
