I have a similar, but less serious problem.
I use a mppt 75/10 with a Liontron lithium battery. It stops bulk loading early at 80% and starts floating at 85%. I tried to set the absorption voltage 0.2volt higher to no effect. The battery voltage is then still lower then the absorption voltage set. Has anyone any suggestions?
