JKBMS settings
  1. Always top balance your cells on a DIY battery pack
  2. Calibrate the Voltage with a 2-digit multimeter.
  3. For amp calibration, you need a constant source, but fw 19.10 also has 0 Ams calibration.
  4. For Victron, disable float on JK
  5. Use the settings from this spreadsheet (Specifically, column D, as provided by Andy) as a starting point.
  6. Ignore the SoC from JK; it’s rubbish
  7. Use the Victron Shunt, forget about JK
I prefer aggressive settings, and the batteries should last 10 years. I hope to live another 10 years and upgrade the packs.
