Hello everyone, I have recently commissioned an off grid solar system per the below description. I am experiencing some stability issues between the Fronius GEN24 and the Victron when there is a fast reduction of load - Every time there is a load reduction of say 2kW, the Fronius disconnects (due to Frequency going to 53Hz) and then it stays offline for about 2 mins before reconnecting. This is causing many disconnect events every day as household loads fluctuate.
- 6kW Fronius Gen24 Primo Plus
- Connected to 60kWH 400V BYD Atto 3 battery back via Dala Battery Emulator
- Connencted to 4.6kW Solar Array
- 5kVA Victron Multiplus-ii
- Connected to 170Ah Lead Acid batteries (charged via 120A 400V-48V Charger connected to BYD battery pack) I am aware the batteries are a bit small
- Connected to Cerbo GX Device
The Fronius is AC coupled to the Victron and is configured as follows:
- Grid Settings set to 50Hz Microgrid (Documentation keeps mentioning MG50 but that isn’t on the list!)
- Power limit set to 3kW (due to limited capacity of the SLA battery bank on Victron)
- Solar API on
- Smart meter placed on the load side
The Victron is configured as follows:
- No grid code selection
- Charger enabled
- PV Inverter Support Assistant enabled, PV inverter restart after battery voltage below 55V. Reduce power 50.2Hz, Min 52.7Hz, Disconnect 53Hz. Installed PV inverter power 5kW, same for solar array
Does anyone have any advice on how to make the load transients a little smoother so that they don’t disconnect the Fronius every time?
Also, I read that the Cerbo GX is supposed to be controlling the Fronius via Modbus, but I don’t think that is happening. The GEN24 shows under Settings/Devices with all the right information displayed there, but in the summary page, the information is not visible.
Below is the image of the Fronius dashboard, where grid is shown, is basically the Multiplus-ii. When there is a load drop, the fronius inverter shuts off, battery disconnects and solar generation stops and doesn’t reconnect until about 2 minutes later.
Here is the view just after the load reduced:
Any advice would be greatly appreciated!
Thanks.
