Same issue for me !
Gateway DESS error code: No matching schedule available 2024-10-26 13:00:01
I thinks it’s a global problem
Same issue for me !
Same issue here. Does not go away if I remove battery restrictions. Regards, Gerd
There is no schedule for tomorrow shown, although it should be there. Issue with the time change to winter time this night? Gerd.
Probably you find the issue ![]()
So we just need to survive time change, after everything will work
anyway mostlikely there will be no fix till Monday
DESS schedule is stopped on 4 am - the point when the time should be changed to Winter Time.
I hope after that everything will be scheduled as it should be.
So, we have to relax and have a rest until tomorrow’s morning )
Same here. No schedule activated.
Maybe a global system error? ![]()
Same issue in Spain. We are falling back (1 hour) tomorrow - 27oct@3:00.
Could it be related?
The schedule “finishes” tomorrow at the time when we fall back an hour @2:59.
Edit after hour fall back:
It fixed itself a few hours after the hour fall back.
Yep problem solved.
DESS will survive ![]()
In Estonia DESS error. Horrible. Maybe bought Huiawey ?
All fine in Estonia. Seems it is not geographically affected.
The recent reports (October 26 and after) are because of a DST change related issues that Dynamic ESS had. We’re going to fix that internally, but the issue does not persist now.
Sorry about that.
