Dear Lucian, there is, at least, another case with connection / communication issues.
I got the Victron EV Charging Station a long time ago, at the time when it’s price EX-VAT was above 1,5k€.
For many months, besides it had good Wi-Fi signal, the connection of the EVCS with my TP Link router (2,4GHz) was totally unreliable, one day the full day Ok, the next not, then a couple hours Ok, after that a full week disconnected, three hours more connected, three weeks more unreachable, this was its usual behavior.
At home I have dozens of devices connected to the router flawlessly, the only one that hasn’t worked was the EVCS.
The solution for the connection problem was to use a dedicated Unifi Ubiquiti UAP AC Wi-Fi Access Point for the EVCS. It didn’t have more connection / communication issues, until firmware 2.0 was released.
When I updated to firmware 2.0 It didn’t go well: Error “W-104: GX communication warning”, the situation was:
I’ve checked the GX configuration in the EVCS side and everything looked good.
I tried to update it several times having always the same result, so I downgraded to 1.30 to be able to keep using the charger…
Anyway, with the Ubiquiti AP, the connection / communication between EVCS and GX was fine until firmware 1.30, not fine with 2.0.
Considering the persistent and recurrent connection / communication issues that the EV Charging Station had, and mine has not been the only one, the over price of the unit at that time compared with the competition, payed happily assuming a supposed free of trouble integration with a Victron ESS system, it would be highly appreciated that Victron offered an Ethernet connector as a retrofit complement for existing EVCS, to be finally free of this kind of troubles.
Thanks for your consideration.
