EV Charger integrated into home assistant via MQTT
Hi all,
I got my new EV Charger integrated into Home Assistant and thought others might find that useful.
Code here
Firstly credits to SmartyVan, I had some basic Home Assistant MQTT integration setup but his video and code is next level..!
To get this working I thought would provide the steps as it wasn’t straight forward :slight_smile:
Steps
Physical install of the Victron EV Charger Make sure that the firmware is updated, this has to be done either via the VRM portal or locally you will be best to ask the installer as the firmware is only available to those with a Victron professional account. If you have any issues installing the firmware install it at least twice preferably locally. Yes that sounds strange, but it worked for me. EV Charging Station hangs after firmware update - #2 by Lpopescu
Configure GX Firstly update the firmware on this via the VRM portal. You need a relatively new version of Venus OS to work properly. 5. Setup, configuration & operation My EV charger did not automatically appear and I had to search and manually update
Configure EV Charger Follow the manual to connect the EV charger to your WIFI. Make sure it’s the same network as your GX device. Configure the GX device comms and also include the GX in the whitelist. Check comms if this doesn’t pass you must resolve that first Manual - EV Charging Station
Solar forecast If you would like to include the solar forecast you can refer to this. :slight_smile: GitHub - BJReplay/ha-solcast-solar: Solcast Integration for Home Assistant
You should now be able to see the EV Charger in the GX (and VRM portal) and from the EV Charger see stats like solar, battery etc
Please use my example code and you should be able to get a dashboard with controls up and running.
Matt
Thank you for sharing this stuff! You saved me effort and energy.
I managed to setup mqtt entity for “EV Charger Mode” as “Select” - so entity has then drop down itself - and automaticaly set Mode.
Here is part of my config for your “victron.yaml”
mqtt:
  select:
    - name: "EV Charger Mode"
      unique_id: "ev_charger_mode_setable"
      state_topic: "victron/N/<device_id>/evcharger/40/Mode"
      command_topic: "victron/W/<device_id>/evcharger/40/Mode"
      value_template: >-
        {% set modes = ['Manual', 'Auto', 'Scheduled'] %}
        {{ modes[value_json.value] if value_json.value in [0, 1, 2] else 'Unknown' }}
      command_template: >-
        {% set mode_map = {'Manual': 0, 'Auto': 1, 'Scheduled': 2} %}
        {"value": {{ mode_map[value] }} }
      options:
        - "Manual"
        - "Auto"
        - "Scheduled"
      optimistic: false
      device:
        identifiers: ["Cerbo GX"]
        manufacturer: "Victron Energy"
        model: "Cerbo GX"
And here is configuration for “EV Charger Auto Start” (Automatically start charging when cable is plugged in)
mqtt:
  switch:
    # Automatic start of charger when cabel is plugged in
    - name: "EV Charger Auto Start"
      unique_id: "ev_charger_auto_start_asddx7"
      state_topic: "victron/N/<device_id>/evcharger/40/AutoStart"
      command_topic: "victron/W/<device_id>/evcharger/40/AutoStart"
      state_on: '{"value":1.0}'
      state_off: '{"value":0.0}'
      payload_on: '{"value":1.0}'
      payload_off: '{"value":0.0}'
      optimistic: false
      device:
        model: "Cerbo GX"
For all the Victron MQTT gang. I created a custom integration which is supposed to do exactly what is described here but with zero manual configuration. I will be glad if you want to test it and supply feedback. You can find it here: Victron Venus MQTT Integration. With this approach, there is no need to install Mosquitto or to connect it to the CerboGX, as the integration has its own MQTT client. It will auto discover the Cerbo GX and just start fetching the MQTT messages.
