Dyness SOC with Voltage cap in dvcc
Could you please elaborate a bit more ?
Yes, that has to happend so the current flow will take the intended path.
But, being BMS controlled, the Multiplus charger parameters should be ignored, right ?
The AC coupled always power consumers and feed-in the excess but sometimes, with less irradiation, I thought to enable DC feed-in to reach the maximum allowed.
Is it a good practice to use the MPPT only for battery and, if required, for “helping” the Multiplus ?
CVL never shifted from 56.5v
