Diy build advice
These were the parts I was looking at buying.
I plan to add 3 more 12v 100ah batteries and 3 more panels at some point in 2p/2s config so want to future proof as best as possible. This is for the garage but will use it as needs for the house lighting etc during power cuts.
Haddock LiFePO4 Battery 12V 100Ah
VOLTACON Elite Solar Panel 430Watt, 95Watt Back Side, Bi-Facial All Black Half-Cut
Victron Energy SmartSolar MPPT Tr VE 150/100
12V to 240V 1500W Car Inverter 3000W Peak
Will all that work ok together?
Panels will be about a 20m cable run from the controller so not sure about cable size.
Will that controller work ok with just 1 panel till I get more? Also seeing people with this controller have voltage reading issues, is is a big problem?
Thanks in advance.
Quick look seems it would be better to get another battery to make 24v and swap out the inverter for a 24v one instead to keep cable sizes down.
That sound right?
