Hi. I am looking to connect a double pole RCD (as per UK regs) to my Phoenix 1200va via the socket. The inverter has a floating ground as standard but does it it need to be switched to bonded in order for a double pole RCD to work? Thanks, James
Related topics
| Topic | Replies | Views | Activity | |
| Floating or Bonded Neutral? (Phoenix 1200) | 2 | 953 | 30 September 2024 | |
| Phoenix 12/1200 inverter error issue | 2 | 85 | 12 October 2025 | |
| Victron Phoenix Bonding | 2 | 107 | 16 February 2026 | |
| Victron Phoenix Inverter AC Ground/Earth? | 2 | 664 | 7 June 2025 | |
| Phoenix inverters - PE-N bridge | 1 | 89 | 4 March 2026 |
