Compare kwh produced of each mppt
In the Vrm portal is there a way to compare the total kwh each string/mppt produced over an extended period of time such as 6 months or even a year? Id like to be able to compare the performance.
I have 2 x RS 450/200
All I can see average voltage/amps in the advanced section in the advanced tab. Its not easy to to decipher this into any usefull data
Indeed.
Grab the VRM manual, look up the section on custom widgets.
Then pick the devices and metrics you want in a chart.
