Hi all,
I’m after some clarity on why one shouldn’t connect an inverter to the Victron Smart Battery Connect, as the explanations given don’t make sense to me. The two explanations I can find are as follows.
- A “current in-rush” may damage the SBC.
Surely this depends on the load generated by the inverter, no? If I have a 220A SBC, and a small inverter that draws a maximum of 10-15A, I fail to see the risk of “current in-rush”.
The initial current draw for such a small inverter would never get anywhere near the rated 220A of the SBC.
- The other explanation is “a reverse current may flow”.
But then, when looking into when/how this would happen, the explanations are along the lines of "if the positive and negative cables are connected to the wrong terminals on the battery, or other wiring issues.”
Yeah… No **** it will cause damage if you wire it wrong
, but that’s a completely different problem, not a reason to never connect an inverter.
I get not pushing the limits, e.g., don’t connect a 100A inverter load to a 100A SBC.
But I’m yet to find a satisfactory explanation why you can’t connect a small inverter that is well below the limit of what the SBC is rated for.
Can anyone tell me specifically what the issue with running a sensible-sized inverter is, if there really is one at all?
Cheers all.
