Change realy state MQTT to other GX device
Can I modify state of relay/0 or /1 from node red with mqtt to other GX device?
with Mqtt explorer I can see that is send the changes but the relay on itself is not changing state.
I probably do someting wrong but i don’t see what :slight_smile:
ok I solved the problem with the use of Modbus TCP communication between the devices.
