Cerbo GX updated UI 3.50 bluetooth functions for Ruuvi
Doh!
Homer_Doh-4154519347
Ouch, not sure how I recover from such a silly mistake!
Thanks for pointing this out!
I am noticing that I have to sign out from my VRM page and sign back in again to see the ruuvi tags on the Remote Console even when they are showing on the GX Display. I noticed this pattern yesterday. The ruuvi tags were not showing on the VRM: Remote Console in the evening, even tho they were showing earlier in the day. Singing out and back in again fixed this.
I don’t know if this information helps or not. I am not doing rigorous bug testing…
Hey Bill, thank you for all the feedback. Meanwhile we’re on to something (s).
With regards to signing out: I expect that refeshing/reloading the page (F5) has tge same result.
Hello Matthijs,
I will try a refresh next time when/if I notice the problem with see the ruuvi tags in the Remote Console I/O page. Thanks for the tip!
Related but maybe not.
I have had my Ruuvi tags reporting temp alarms as it should to my email inbox, BUT they are only in Celsius and not Fahrenheit as all my other pages in the VRM portal are indicating.
These emails are the ONLY place that is reporting Celsius. Where can I change the format of the emails or where the source data is???
Thanks,
Kurt
You could try
Remote Consol>Settings>Display and Language>Units
Or you might have to do it in the Ruuvi app.
EDIT
Yes it’s in the Ruuvi app under app settings>Temperature unit
I set that up when I first installed them.
Hi both,
Thanks for reporting!
Those alarm emails unfortunately can’t be formatted from Celsius vs Fahrenheit.
There is no immediate straight forward fix either, due to the way that their generation has been set up.
This is going to take quite a while before it is changed.
All the best, Matthijs
Thank you for the update. At least I know I’m not chasing a unicorn now. :grin:
Just to ensure I’m not wasting money, I have a Venus GX, but there’s no Bluetooth section in my Venus OS settings.
If I purchase a compatible Bluetooth adapter, will it appear in the Settings menu?
I recall a previous forum discussion about these adapters and the Venus GX, where it was mentioned that Bluetooth needs to be disabled for the dongle to be recognized. However, I don’t see any Bluetooth option to disable.
For reference, I’m running Venus GX with firmware version 3.31.
I understand emails notifications are fixed to Celsius. However, can push notifications be done in Fahrenheit? Or is it the same “back end” that is doing the notifications. Thanks. Ian
Hi @CCB,
That should be fine to buy one of the bluetooth adapters listed in the manual.
Don’t worry about the need to disable anything if you don’t see the option.
