Cerbo GX Mk2 with v3.66-Large, how to install fuseflow (node-red-dashboard-2)
I seem to be unable to locate the node-red-dashboard-2 or @fuseflow/node-red-dashboard in the pallette for available to install.
ChatGPT seems to point towards SSH and using NPM to install it cause it is still in pre-release.
However, it seems like v3.66 makes it increasingly hard to get SSH turned on.
Is there a simple way to add the dashboard to Node-Red or should I continue down the path on using Console to get into my Cerbo and manually enable SSH so then I can remotely connect to it to install via NPM?
Have you tried searching for @flowfuse/node-red-dashboard ?
Yeah, I tried that and the node-red-dashboard-2
Even just fuseflow and nothing comes up, the original node-red-dashboard comes up and there is over 5000 packages listed, just not that.
flowfuse, not fuseflow
Sadly was led astray by ChatGPT and did the classic error of not double checking…. stupid me.
Thanks mate, didn’t recognise the nuance of the flipped name.
So on the flip side, I found the support document on how to enable super user and enable SSH on LAN. So I can log into the OS now. But yeah would prefer to do things as “out of box” as possible. So will install via the pallets. Thanks again
Never take (the output of) an AI for granted :slight_smile:
