hello, Can you help mi with connection my Cerbo GX with Loxone via modbus TCP? Cerbo is connected on my loccal ethernet with cable, I would like to some how connect Cerbo to Loxone.
The idea is use the same ethernet cable on cerbo side and use Modbus extension on Loxone side.
I’ve linked the Cerbo to loxone here. You can just use modbus over ip, no need for the modbus extension or any other hardware, they just need to be connected to the network. There are templates available in the loxone library so you don’t have to figure out all the registers:
One extra question, I have my data from victron in to the loxone, but during the day when my meter is counting minus value (feeding to grid) Loxone is receiving just plus value.
So you see the negative values in loxone using live view, but your meter is not showing them ? Did you use a bidirectional meter block in loxone instead of the regular meter block ?
