Can I charge batteries using a portable Honda EU22i generator to a Multiplus II?
The generator works well with my Victron IP43 charger, but that is for 12v output only. I’m looking to install a 24v Multiplus II.
That should work as long as it is not an ESS system.
Depending on the model, you must set the input current limit to match the generator output.
Also set the battery charge current as not to overload the EU22 “continuous” output rating.
