Maybe a third board is in order ?..
Just kidding, I am sure you will manage it in the end with what you have now…
But there are some people that tried these boards below and worked, because venus os seems to have already the drivers for them. Here, I asked something about it.
For CAN communications: There are several SPI to CAN boards out there, but some need to be modified to work with the 3v3 logic of the R-pi.
One can then code directly accessing the CAN device registers over the SPI port. I don’t know if there are any standard drivers for Venus to access CAN via the SPI, but that should also be possible. You can write your own driver to get the BMS data from the SPI and send that to the d-bus message system.
Yes i’m learning that also now, Chat GPT is guessing a lot
but I can see a new rabbithole in front me, with a CAN-Hat solution for the RasberryPI
I’m a total noob, and don’t even know what SPI means.
