Yes, this is the main breaker at the batteries. My plan is to put it in the battery box itself, so an auto reset breaker that works both ways is the goal. something like this, but that is still polarized.
That one is single pole. Known for nonsense tripping. So be careful with your choice.
You could always fuse one side (positive) and have a disconnect on the other pole.
Size your fuse/breaker about 1.25 x expected current (rounded to nearest size)
OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
5
In my humble opinion, there are no suitable, safe, and low-cost DC circuit breakers. The key words are “low-cost”. Properly extinguishing a DC arc upon closing or opening under load is no small feat, especially at high current. And as LX indicated, the interrupting current rating for low-cost DC breakers is too small. Quality DC circuit breakers at suitable interrupting current are very expensive.
Put more simply, use a fast-acting, high interrupt current fuse as close to the battery terminals as possible.
You didn’t give us your battery voltage. At 12V or 24V, use an MRBF terminal fuse on the positive battery terminal. If 48V, use a Class-T fuse or suitable equivalent in your country. If you need a battery disconnect, use a quality DC switch like a Blue Sea 6006.
I agree with @OGPS that finding cheap suitable breakers is very difficult. Mine were especially made and fairly expensive. Yes, I looked at ABB and Siemens. They had many DC breakers but they were not suitable. But then, mine is a 48v system.
