ho ok, I didn’t know it was normal behavior
Thanks for the explanations ! ![]()
And so we can create our own charts… interesting ! ![]()
@nickdb I just finish to read your link about Pylontech and Victron.
The answer of my previous question about the temperature was in it ![]()
Thanks again, I’ll keep it in my bookmarks for sure ^^
It is normal. I also have 2 pylontech us5000 with mpii 5kw and mppt 250/80 that I installed almost 3 years ago. I am off-grid too.
Pylontech bms manages battery charge and tine to tine it decides to cap max SOC lower than 100% for some weeks and later moves again to 100% SOC. In my case use to be at 95%, 98% or 93%. I want to understand that there is sone cell imbalance and bms limits max charge until cell imbalance is solved.
I was surprised when I installed the batteries for the first tine as I stayed more than 2 months lower than 100% and later SOC reached 100%.
Actually i am in the period where SOC is capped to a maximum of 95%.
Hi Josep, Thanks for the info !
Look at this. This is august 2024. SOC reaches 98% and stays there for almost all the day and later jump to 100% suddenly. I am not an expert at all but i eant ro understand that the reason is that there is cell imbalance and the bms algorithm limits charge while cell balancing is done. An expert as @nickdb or @alexpescaru should confirm.
Hi Josep,
After some days, the charge came back to 100% indeed ![]()
Thanks !
And Thanks anybody else, I’ve learned a lot with those exchanges ![]()
