Hi guys, I have a smart charger 100/20 and a Phoenix 12/375 connected to a 12v leaked acid battery. I setting the battery life algorithm to control the load trough a relay connected to the load output charger to control on/off inverter connector, but the voltage battery go below 11.1 volt and the inverter go in low voltage protection, why? It is normal behavior? Is battery life algorithm corrected implemented. I think that battery could be damaged. The TX ve port pin is connected to an esp32 to read parameters trough Home assistant.
Related topics
Topic | Replies | Views | Activity | |
Phoenix 12/250 Low Battery Alarm | 0 | 38 | 25 March 2025 | |
Phoenix Inverter not restarting | 0 | 39 | 2 May 2025 | |
Phoenix 12/1200 alarm voltage batterrie chargee a fond | 0 | 21 | 4 October 2024 | |
Phoenix 1200 Restart/Alarm and Low Voltage settings | 2 | 87 | 16 November 2024 | |
Low volt shut down | 2 | 176 | 6 February 2025 |
