Is there an easy way to add a second “Tank Pump” relay to Ekrano? It only allows you to configure relay 1 as a a “tank pump”. If you add an IO extender 150 can one of those relays be configures as a “tank pump”?
Related topics
| Topic | Replies | Views | Activity | |
| Cerbo GX Relais 1 and 2 configured as tank pump | 1 | 70 | 11 July 2026 | |
| Auswahl der funktionen der relais beim cerbo GX zu gering | 2 | 67 | 30 September 2026 | |
| More relays on Cerbo GX | 3 | 1365 | 12 June 2025 | |
| Darstellen von Digitalen E/A im Ekrano GX | 4 | 82 | 12 May 2026 | |
| Cerbo GX Relay 2, Naming & Ability To Modify | 0 | 43 | 23 August 2026 |
