Hello all.
Background: my ESS installation consists of single-phase 5kVA MultiPlus-II, one 450|100 MPPT RS, 6.25kW Panels Half-Half E-W alignment & 16kWh DIY Battery. This is all managed by a Raspberry Pi-4 running Venus OS. It receives battery information from the battery via a Waveshare CAN-Hat but only for information. A smart shunt is the battery monitor and VM3P75CT is the grid meter.
Sometimes household loads exceed the 4kW limit of the inverter leading to undesired grid usage. I have a solar thermal water heater on the West roof that needs some ‘help’ from its in-built electric 1.5kW immersion heater. This is primarily used during ‘winter’ (cloudy) season at my near-equator location.
I am looking for a way to switch off the water heater when total loads approach/exceed tge inverter’s 4kW max, and then keep it off for a while(to be decided) when loads decrease beyond a threshold (to be decided). The ‘to be decided’ values should be adjustable.
So far, I’m leaning towards an implementation using Home Assistant and a Sonoff Smart Switch. However, I would like to hear of any more elegant solutions.
