Hi, I’ve just joined this forum and I’m pretty green to this stuff but have decided to build by own 24v system rather than buying an off the shelf setup. In at the deep end!!!
I’m trawling through you tube, google, here and basically anywhere i can find info. Its confusing to say the least, with component upgrades and comm connection protocols, its impossible to understand.
So hopefully some of you would be kind enough to pass on some of your knowledge and save me the inevitable cock up/expense of getting the wrong components. Even though that might be a tad late.
Obviously for a van conversion, it’ll need shore hook up, solar, battery storage and B2B of some description. I should perhaps say i’m converting a 2025 LWB VW Crafter, so have a reasonable amount of space to play with.
I’ve opted for a 24V system, because i believe its the half way option between struggling on 12v and going completely overboard with 48v, but really because i intend to run a split aircon system and fridge freezer that are both 24V. I did appreciate the complexity of 12 to 24 & back, but perhaps not the cost of that!!
So far I’ve spent a kings ransom on the more expensive components which are:
Multiplus-II GX 24/3000/70
Titan Lithium 24v 230ah batteries (x 2)
SmartSolar MPPT 100/50
Lynx Distributor (M10)
Smart Shunt 500A, perhaps should have been 300A
I was intending to use:
DMEGC 500W solar panels (x4)
Stirling B2B BB1224120 bi-directional charger (Victron do not seem to produce an equivalent, but either option is £$£$£$£$£, not sure of other options ‘Scotty comes to mind’. Might end up running a 12v alternator and a 24v one??)
The problematic parts seem to be comms between devices and how you can/should connect them to talk!! I haven’t even looked at the Stirling B2B yet but have seen it used with Victron Systems on You Tube, so know its possible. Being Bi-Directional seems to be a bonus.
So I’ve looked at:
Raspberry Pi 5 with 10.1” monitor and UART/USB cables, Bluetooth connections and WiFi.
Question;
What i thought would be a straight forward process of connecting all these victron parts together and monitoring them on the APP or VRM, seems to be screwed up by picking the Multiplus-II GX over the Multiplus-II and a Cerbo with display.
Conflicting info on connecting a Cerbo to MP-II GX (as in only one GX device can be used?!), or using bluetooth, wifi or an array of DIY/Hacked components.
So anyway now I’m committed to the MP-II GX, how on earth do I get the system to talk? I assume the inbuilt BMS in the Titan batteries will connect to the MP-II GX (internal port on GX card or external port)? The Titan batteries do have an ethernet cable which daisy chains through the paralleled batteries to the MP-II GX even though they have built-in bluetooth, both Victron and Titan say these are compatible.
So I’ve gone on enough! Any suggestions on components and options to connect them all up to monitor/talk would be greatly appreciated. Maybe this will also be helpful to others.
