@Yachtbird Hey, Trevor! Having read your paper, I wanted to clarify whether or not a device of the likes you mentioned exists on the market today. At the end of your paper you mentioned the idea of introducing an inductive current to reduce the capacitive leakage current. Is this something that is possible, and if so, how would I go about it? I am asking to see if I can find assistance in solving a similar issue that I outlined here: Can I use a Victron Isolation Transformer on the input side to prevent GFI's tripping while charging - #7 by SamuelSullivan
SamuelSullivan
(Samuel)
3
Related topics
| Topic | Replies | Views | Activity | |
| Can I use a Victron Isolation Transformer on the input side to prevent GFI's tripping while charging | 30 | 517 | 3 July 2025 | |
| Multiplus-II 2x120V tripping GFCI | 54 | 1727 | 23 October 2025 | |
| 120V 15A GFCI Shore Power Trips When Victron Quattro Is Running 240V Split-Phase | 0 | 69 | 11 June 2025 | |
| GFCI Trouble Shooting Multiplus | 50 | 1979 | 23 July 2025 | |
| RCD tripping on my ATLAS COPCO P8000T on connect | 6 | 148 | 15 September 2025 |
