Please reduce the absorption voltage from 14.6 to 14.4v .
Ludo, I’m happy to try that setting. Can you provide reasoning for that beyond not being happy with the data sheets. I am interested in knowing why more technically.
Thanks
A result of too high absorption voltage…
Actually, while not changing any configuration once I discovered the connection error on the shunt, I fixed the error, then did a draw down watching the data closely. I drew down the batteries to about %40 percent and all the indications were appropriate and expected. That, as it turns out, was the root cause of the problem, not that I had had the absorption value set to 14.6.
So, as a result, I’m sticking with the 14.6 as specified in the technical documentation by ReLion for my batteries. Any other setting that I may choose to make will only be done so by substantial support for the change, and that means anything other than an opinion.
Thanks again to both of you for the input.
