JK BMS and DVCC
No, sorry. I’m not old enough, yet, to waste a perfectly good job :joy: As in I work as a contractor on projects and they won’t like it when I spill their beans.
No problem, thanks anyway. If i don’t ask I will never know. Have fun.
I’ve identified some problems with this procedure:
  1. How can I have a stable current when I have 6 parallel batteries on 3x Multiplus II 15000VA?
  2. I need to disconnect and calibrate the voltage on each battery, but is connected to Lynx PowerIn
  3. On each firmware update, all the values are reset, so I need to recalibrate all the batteries
NOT FUN, too much work, complicated procedure.
  1. One at a time. Set to keep batteries charged → stable charging from grid. Also set a low grid current limit to not overload your battery / use DVCC limit.
  2. Yes
  3. Only update BMS if you really need some fixes in a newer firmware. Otherwise leave BMS alone.
Maybe it’s fun, maybe not. For me its a hobby. And faster to calibrate 6 batteries than change a waterpump or brake pads in my car for example.
Hello, I have a problem with my Victron system. It contains 2 MPPT chargers, a BMV 702 and a cerbo gx. It also has a 200 Ah lifepo4 battery pack V19 jkpb2a16s15p BMS with CAN bus connection. My problem is that my MPPT controller does not want to switch from absorption charging to trickle charging, even though the 100% charge level is met. What could be the problem? DVCC is on. It doesn’t matter what I set as “Battery monitor” Bmv or BMS, it doesn’t switch.
