Deliberatly Limiting batteries charge
Cycling near the top of charge (75%–100% SOC) is detrimental to LFP/graphite cells. Our results show a correlation between the average SOC of battery operation and capacity fade rate, meaning that the lower the average SOC, the longer the lifetime, in these 2500 h of testing. The average SOC was found to be the most critical factor influencing capacity fade for LFP cells, over the factors of temperature, depth of discharge, electrolyte salt choice or graphite choice. Cells cycled in the conventional 0%–100% SOC window showed capacity fade rates intermediate to 0%–25% and 75%–100%. Therefore, the time spent cycling at high states of charge is critical to minimize.
https://iopscience.iop.org/article/10.1149/1945-7111/ad6cbd/pdf
