Hi, is there a way to display the measured temperatures on the preset screens so it is easy to access? The only way i was able to find out is to go into the settings.
Thank you
Stefan
Thank you
Stefan
Not with the current firmware versions unless you add external add on programmes, GuiMods comes to mind, look in the modifications section and search for GuiMods.
Alternatively, wait a month or two as Victron are currently developing an upgrade which will have temperatures on their own page. Again look on the modifications page under Venus OS v3.40~2, beta testing will continue shortly.
https://community.victronenergy.com/questions/270759/venus-os-v3401-available-for-testing.html
Victron temperature sensor disambiguation table - which product supports which sensor
24 People are following this question.
