Andrew Jefferies avatar image
Andrew Jefferies asked
"Proxy relay not found"
For some months I have not been unable to access Venus OS large from VRM. I get the message "Proxy Relay Not Found". OK from LAN , (Cerbo-gx-ip):1880/UI/ , but NOT from VRM on LAN or Internet, It did work a while ago.
VRMNode-REDRelay
Jarco van Roest (Victron Energy Staff) avatar image
Jarco van Roest (Victron Energy Staff) answered ·
Hi both, do you have the remote support turned off? Try turning it on and rebooting the GX and check if the proxy works then
Andrew Jefferies avatar image Andrew Jefferies commented ·
Proxy rerlay not found .... Again.
slqa avatar image
slqa answered ·
Did you figured out what was a problem? I just started using nodered and have same issue.
I had remote support turned "OFF", NOW "ON" & working BUT it didnt work immediately, even after Cerbo reboot.. However TODAY, a few days afterwards, it works. So I don't actually know where the error was.
slqa avatar image
slqa answered ·
Hi Jarco,
That indeed helps.
It will be worth to add this info into github Wiki.
