tittiger avatar image
tittiger asked
Has Victor on considered adding a monitor alarm on the phone app?
I have noticed that the Victron monitor alarm way back in the bedroom it is not Audible so I am wondering why victron has not added an alarm to the phone app that will go off that I can hear? Bluetooth connects to the bedroom battery monitor so if the phone app had an alarm on it I would hear it.
BMV Battery Monitor
Alexandra avatar image
Alexandra answered ·
@tittiger
Chances are if you are out of earshot of the audible alarm, Bluetooth range has been exceeded.
For the most part the VRM is for remote monitoring and that has push notifications. If you have a GX (and some other products) then you can use the relays to trigger the sound from a much larger alarm if only local is wanted/needed.
The BMV also has a relay that can be used to trigger a louder buzzer and/or light in case of an alarm.
VictronConnect and the smart devices are not designed to have a permanent connection and because of that it's not possible to have an alarm on you phone via Bluetooth.
