jacom avatar image
jacom asked
Multiplus firmware update blocks VictronConnect
Multiplus 12/800/35-16, 2022
Hi, After some time, I switched on my Multiplus, connected to it using the Victron app on my iPhone. The app asked to update the Multiplus firmware, I said yes and it began updating. Finished succesfully and functioning. After that, I wanted to change a setting in my Multiplus using my laptop and now VictronConnect complains that the Multiplus has a manual firmware update which is unsupported by VictronConnect. I have the latest version of VictronConnect (6.04). What should I do to fix this/to be able to change my Multiplus settings? Thanks in advance. (no help from Victron or my online supplier…)
Multiplus-IIfirmware update
nickdb avatar image
nickdb answered ·
Firstly, don't update firmware just because there is a new version. Updates are not mandatory and should only be done on a working system if you are fixing an issue or need new functionality.
Updates can introduce problems.
The latest version is 6.05.
I believe this resolves the issue.
And dont forget to reprogram the inverter afterwards.
