Hi all,
I'm installing a 250/100 mppt to 2 x 3000 pylontech batteries. What size cables should I be using.
Thanks for your help
Hi all,
There are so many questions about wire sizing, please use the search function.
The needed cross section is calculated with the wire length, the current and voltage.
With Google you can also find many calculators for that.
The datasheet tells you the max. that fit into the terminals.
105 People are following this question.
