luphi avatar image
luphi asked
EVCS automatic switching between 1p and 3p
In https://community.victronenergy.com/questions/215013/single-phase-charging-on-three-phase-setup.html
@Lucian Popescu (Victron Energy Staff) describes a not officially supported method to make that work with the existing EVCS models. On the hardware side, the 4p contactor has to be replaced by 2x2p contactors. 1st contactor for P1 and N, 2nd contactor for P2 and P3. The 2nd contactor will be switched by the 2nd relay, which is not in use in the original setup.
These contactors might work: https://www.se.com/de/de/product/A9C20842/installationssch%C3%BCtz-ict-40a-2s-220-240v-50hz/ They are a bit wider, but should fit. Probably the DIN rail needs to be extended.
On software side, the modbus register 5056 hat to be set to 2
But before I'm going to invest in the contactors (btw, street prices are far below the list price), I wanted to play with the modbus register, to see, how the EVCS behaves. The documentation says, range is 0-2 and default is 1. But when I read it, the value is 65535 and I'm not able to change it.
$ mbpoll -1 -0 -a1 -r5055 -c2 evcs
mbpoll 1.0-0 - FieldTalk(tm) Modbus(R) Master Simulator
Copyright © 2015-2019 Pascal JEAN, https://github.com/epsilonrt/mbpoll
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions; type 'mbpoll -w' for details.
Protocol configuration: Modbus TCP
Slave configuration...: address = [1]
                        start reference = 5055, count = 2
Communication.........: 172.23.1.15, port 502, t/o 1.00 s, poll rate 1000 ms
Data type.............: 16-bit register, output (holding) register table
-- Polling slave 1...
[5055]:     65535 (-1)
[5056]:     65535 (-1)
Can please anyone confirm or proof me wrong.
Cheers... luphi
evcs
Lucian Popescu (Victron Energy Staff) avatar image
Lucian Popescu (Victron Energy Staff) answered ·
You can change it
luphi avatar image
luphi answered ·
Hello @Lucian Popescu (Victron Energy Staff), thank you (again) for your quick response, but I can't change it. When I try, it says "Written 1 references" but when I poll again the value stays unchanged.
By the way, other registers like 5017 (max current) are working fine.
$ mbpoll -0 -1 -a1 -r5056 evcs 2
                        start reference = 5056, count = 1
Communication.........: evcs, port 502, t/o 1.00 s, poll rate 1000 ms
Written 1 references.
$ mbpoll -0 -1 -a1 -r5055 -c5 evcs
                        start reference = 5055, count = 5
[5055]: 65535 (-1)
[5056]: 65535 (-1)
[5057]: 65535 (-1)
[5058]: 65535 (-1)
[5059]: 65535 (-1)
luphi avatar image
luphi answered ·
nobody with any ideas? Any help is really appreciated.
Cheers... luphi
It should work, I have just tested
luphi avatar image luphi Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Thank you for double checking. So, what am I doing wrong? Do you use a different modbus tool to change them? Since I can change other registers, I don't believe, it's a tool issue. Have you had the same default values 65535? I only have these values for the 5 registers, listed above.
Sorry for all the questions, but still can't make it work.
can you give me the vrm portal ID?
luphi avatar image luphi commented ·
send by email
luphi avatar image
luphi answered ·
Hello Lucian, thank you for your help. it's working now.
kds avatar image
kds answered ·
Did you install the contactors finally ?
luphi avatar image
luphi answered ·
Yes, I did. In theory everything should work. I'm really exited to test it out. Unfortunately the car is not yet delivered. The dealer promised he will get it next week....
What I was missing, was modbus register 5100, which enables/disables phase switching. Setting it to 1 makes the registers 5055-5059 changeable.
From hardware perspective, I was indeed going for the contactors mentioned above. (less than 40€ per contactor including shipping in Germany). I had a DIN rail laying around, so I replaced it too, to fit the size of the new contactors.
jochenku avatar image jochenku commented ·
Thank you for the heads-up on this modification, I'm strongly interested in doing it, too, now that solar excess is slowly becoming available again.
Might you be willing to share the exact specifications or even a link to the newly installed contactors/relays? That would be great...
Thanks a ton and best regards,
Jochen
hbraak avatar image
hbraak answered ·
I impleteted the phase switching for the EVCS NS and made a tiny documentation. Comments are appreciated!
BR
Heiko
EVCS_Phasenumschaltung.pdf
4 comments
Nice :)
kudos50 avatar image kudos50 commented ·
Very nice ! Was planning on opening it up soonish to figure things out. Having this is way better :-)
Just one mention, remember that it is a feature still in beta. And it is not supported yet
hias0815 avatar image hias0815 commented ·
Any updates/Results of testing with enough sun?
Is it working as expected?
Regards
Matthias
19andy89 avatar image
19andy89 answered ·
Hello
That's good news
Does the switching of the phases work automatically?
or does the switchover have to be done via Modbus?
Does the car also accept the switch?
hbraak avatar image
hbraak answered ·
Up to now, I tested only the manual mode.
When I switch the Manual Mode via Modbus 5055 from 1 to 0(three phase) during charging the EVCS stops charging, switches to 3-Phase an starts again within a couple of seconds (Parameter 5101 might be the corresponding).
Sun is missing...also next days here in cologne. Testing the auto mode seems to take a while.
May be Lucian can give an explanation to the parameter 5057 - 59 in the Modbus TCP Register List?
Best Regards
Heiko
webblaster avatar image webblaster commented ·
Hello Heiko,
any further experience with the mod?
Greetings from Lindenthal
Felix
hbraak avatar image hbraak webblaster commented ·
works pretty good, parameters I attached below the last post.
luphi avatar image
luphi answered ·
they build the switching hysteresis, I assume:
- switching from 1p to 3p if surplus >(5057)W for (5059)s
- switching from 3p to 1p if surplus <(5058)W for (5059)s
hbraak avatar image hbraak commented ·
Thanks!
luphi avatar image
luphi answered ·
To be honest, I'm not sure, if it is really correct, what I wrote.
I configured 5059 to 10s and 5057 to 4500W. The EVCS is charging since a couple of minutes now with 16A@1p and ~2kW are send to the grid, but it's not switching to 3p :-(
My assumption was, that the EVCS sums up the current charge current + the energy send to the grid and if that is bigger than the value of register 5057, it would switch to 3p. Unfortunately that doesn't happen. Does it really requires 4500W (4800W by default) in addition to the ~3600W 1p charging to switch to 3p?
@Lucian Popescu (Victron Energy Staff) would you mind to clue us up.
Cheers, luphi
hbraak avatar image
hbraak answered ·
screenshot-2024-04-28-202254.pngHere are my parameters for phase switching. Ich works pretty good. My E-UP only can charge via two phases.
BR
Heiko
4 comments
Thanks for sharing.
Does that mean, I should multiply your values by 1.5 ?
hbraak avatar image hbraak luphi commented ·
Hi, it depends on your hardwaresetting. What is your max. current per phase? And what is your EV capable to charge, on how many phases? Can you provide some more info?
BR Heiko
From your previous post is looks like you have max current of 16A per phase (take care of your circuit breaker!) So if your EVCS should switch to 3 Phase mode, you have to take a value for 5057 below 3800W.
If your EV charges at 3 Phases the minimum Power would be 6A * 240V * 3 = 4320W or 2880W for 2 Phases. In the first case I don't know how the set the 5058 parameter, that it would make sense, only if you have a setup for 32A max... For the second case as it is for my e-up the 5058 should be 3800W>(5058)W>2880W. I took 3200.
May be this helps.
luphi avatar image luphi hbraak commented ·
cables and breaker cover 32A
The car (EV6) can charge up to 16A at 1p or 3p, means I have a gap between ~3700W (16A@1p) and ~4200W (6A@3p).
Cheers, luphi
I think so...
but, considering this information:
https://ev-database.org/de/pkw/1471/Kia-EV6-GT#charge-table
It should be possible to go to 32 A for the vehicle. If your cables to the WB ist capable to transport 32A and your circuit breaker is for 32A, then you can got to 32A with the EVCS an your gap should disappear.
BR
Heiko
