I need an RS485 connection from the solar inverter to the wallbox. Can I use two Zigbee RS485 converters for communication?
Regards,
Frank
Regards,
Frank
Zigbees have been supported for a while.
But knowing what you are actually trying to do and with what is not entirely that clear from your post.
Wall box is that the EV charger?
Hello, I need an RS485 connection between a solar inverter (Kostal) and a wallbox (Kostal). Since I can’t run a cable, I’d like to do it wirelessly. I was thinking of feeding the signal from the inverter into one converter and sending it from the second one to the wallbox.
Regards,
Frank
Aha. So nothing Victron in the system?
No, but RS485 isn’t tied to any particular system, is it?
Yes, but this is a Victron forum. So maybe head over to DIY solar to ask there.
