Have an issue where i have 2 Arco Zeus alternators in a system, go to rename them on teh device tab, you can type in the new name but there is no way to Accept the Text as soon as you move away from the page it defaults back to the original name.
am i missing something or is this a bug with the new UI
Try renaming the Zeus regulators themselves, then hopefully they will transmit different names.
Doesn’t work.
This needs resolution. Have installed multiple of these on cats and its a pain not being able to see which unit is doing what.
Did a wake speed a week later and renamed it in the app. It worked that way so assuming the same will happen with Arco. Need to revisit this but sure it would work.
Can we get a resolution to this. I have spoken with Arco, and they assure me it is not an issue on their end. Another catamaran install this week, and it is a pain that the units cannot be differntiated because they cannot be named.
Maybe test the beta or v3.53 which is current prod version.
Doesn’t work in 3.53. And I’m not putting a beta version on a customers device.
That’s absolutely fine, was just a suggestion. Will see if this can be brought to someone’s attention.
The Zeus does not allow setting the name through N2K. They are working on an update to reflect the name given in the app also on N2K, so you can distinguish between multiple units.
