I’ve chosen 8 AWG copper wire to attach my Victron 100/30 to the in-line 40 amp fuse, and from there to a 100aH LIFePO4 battery on the positive side, and 8 awg copper for the negative side of the controller to the battery. Victron recommends multi-stranded wire. Is there a clear preference between 8 AWG Ultra Flexible Stranded Wire, 1650 Strands of 0.08mm Tinned Copper, or 8 Gauge Battery Cable with 186 strands of 24 ga copper? Should I use ferrules with either choice, or is bare wire acceptable for either or both choices for connecting to the Victron MPPT controller ? Thanks!
Ferrules on mppt’s have never been recommended.
Several topics about this on the forum.
Like anything, terms and conditions apply.
Have you followed the wiring unlimited guide?
How flexible the wire needs to be depends on the installation.
In general, standard “Battery” flexible cable is sufficient in mobile applications. For static applications less flexible wire could be used.
Ferules can be used to control stray strands on very flexible cables.
I’ve followed the guide. And this forum helped me decide on awg 8 vs #6, which I found to be difficult to use with the 100/30 contacts. The 100/30 manual states that multistranded is preferred.
I found this on an AI site: " 1650 × 0.08 mm ultra-flexible (tinned copper): Strand diameter is ~0.08 mm (roughly 40 AWG), far below the 0.4 mm limit. This is ultra-fine Class 6-level stranding. It is fully compliant and preferred. Tinned copper is also appropriate (especially for marine/outdoor use). Silicone or high-temp insulation (often ≥200 °C rated) exceeds Victron’s ≥90 °C requirement.
- 186 strands of 24 AWG: 24 AWG has a diameter of ~0.51 mm (0.0201 in), which exceeds the 0.4 mm maximum. Even though 186 strands is a relatively high count for conventional battery cable, the individual strands are too coarse for Victron’s specification. Standard marine/battery cable in this range is often finer (e.g., Type III / Class K with smaller strands); 24 AWG strands are borderline-to-unacceptable here.
Clear preference: the 1650 × 0.08 mm ultra-flexible."
So I’ll go with this as the solution.
And thanks for the confirmation regarding ferrules!
