Winter checks for a home solar and battery setup
As the days get shorter and colder, I have been thinking about what to check on our home solar and battery setup before winter really sets in. I usually look over the panels for leaves and dirt, and check that the battery area stays dry and well ventilated. I also like to review the recent charging patterns to see whether shorter days are changing how much charge is available in the evening. Small habits, like clearing debris and checking connections visually, feel more useful than waiting for a problem to appear. What winter checks do you do on a home solar and battery setup, and is there anything you wish you had checked earlier?
Hi there,as I have got an off grid setup,and reliability is vital,a regular maintanance plan has been setup.It already starts shortly after the summer,when the system gets completely shut down,the inverter opened up and a thorough inspection follows,together with a good clean of the fans.Towards the winter months,because the panels are on ground mount,I also check for loose screws,loose connections and visual damages on the glass.I also rase the charge slighly to compensate for the shorter harvest.As there’s everything done in DIY,it makes it easier,to look where problems might occur and check for the obvious connections etc.I have got jk bms’s which also get restarted from time to time and taken off the connections and put back on,because the jk’s don’t automatecally update their balance wire resistances.I also got a seperate app to monitor everything over the web,so twice a day-at least- when I’m at work I have got the oppertunity to check the whole system.Shortly before the winter,I make sure the white pebbles underneath the panels are free from weed(bifacials) and the neighbour bushes are cut down…I’ve got two strings one east ,the other south’ish which for the winter seems to be ideal,because harvesting is done already with the first sunlight.Mountains block the western side in the winter and therefore sunset is at the early afternoon.The wintermonths above all,make me relize how precious the energy is in an off grid setup and how carefully you need to household those few months,while not thinking much about it in the other months,when the sun gives more than you need.Best regards ,Frank,northern italy
