I have MultiPlus-II 48/30000-35/32, Cerbo GX, Pylontech batteries, I am switching to a lower night time tariff, so have been trying to set the ‘Scheduled Charging’ so far without any success. I am in ‘Optomized Mode’ SoC is below the target set etc.
You should go with “optimised without BatteryLife”…
and is it even worth it? You can only charge at about 1.7 kW from the grid… and around 25% of the power is lost going in and out of the battery..
Thank you Holger for your reply I will monitor the economy of charging in the cheaper off peak tariffs bearing in mind that 25% of power is lost going in and out. The Scheduled charging is now working the problem was obvious but unexpected. I hadn’t realised that the there is a difference of 1hour between the Cerbo GX clock and that displayed on the VRM? As I was using the VRM to set Schedules I was always one hour too late!
SS
