I don’t know if you can help but I have bought a recently converted camper that has an Orion-Tr Smart 12 I 12 - 18 fitted. This has recently started to emit a very high pitch ‘whistle’ that I cannot correct ( or tolerate whilst driving! ). Is there anything that you can suggest or is it a faulty unit?
It’s not faulty… You are just unlucky…
It has some different tolerances for some of the internal components and therefore the high frequency harmonics of the internal DC/DC converter can be heard by those with sensitive hearing.
Try to exchange it, if you can, or relocate it.
Thanks Alex,
Would exchanging it likely see the same result tho? Or was it just an unlucky unit!
Don’t know that…
Depending on the quality of the components used inside.
Search for “coil whine” for more info.
