What is the temperature derating spec for this product?
This series has a maximum temperature setting that is adjustable in software (maximum setting is 60 C)
Derating will start 8 degrees below set maximum temperature.
Derating occurs on Ioutmax.
When set to 60 degrees and output 50A the following derate occurs:
Board temperature | Output current |
52°C or less | 50A |
53°C | 48A |
54°C | 44A |
55°C | 40A |
56°C | 36A |
57°C | 32A |
58°C | 28A |
59°C | 24A |
60°C | 0A |
The TSconfig software displays the PCB temperature, which will be higher than the externally measured case temperature.
