I’m designing an electrical system for my small overland vehicle.
Currently, I’m considering two options:
A cheaper option with a non-Victron battery (built-in BMS).
The non-Victron battery has a built-in heater.
A more expensive option with a Victron battery and an external BMS.
The Victron NG 12.8V, 200Ah battery does not have a built-in heater. Any advice on how to address this would be appreciated. Being able to charge the battery at temperatures below 0°C would be helpful, as I plan to store the vehicle outside during winter.
A battery is as good as it’s back up and supportnif you have a long range view of your system useful life expectancy.
My choice is always based on that. With batteries a cheaper option can actually less cost effective long term.
So without naming brands as it is regional, choose one from a supplier who will back you when there are problems. Unless you don’t mind changing batteries or think you may outgrow it and will change it before 2/3 years.
Thank you for your advice. What about from a functional point of view? In both cases, I will use a Cerbo GX, and I would like to have a good overview of the entire system. What functionality would I actually lose if I chose not to use a Victron battery and BMS?
Yes, the Victron SuperPack NG has a heating function, but it also has a built-in BMS. So I guess there is no option to integrate it with the Cerbo GX (just like with a non-Victron battery)?
OGPS
(Ed @ Off-Grid Power Systems - offgridps.com)
6
The extra functionality depends on the complexity of your system, IMO. The two main benefits of a Victron Lithium NG battery and external BMS are higher charge/discharge rates with Victron’s batteries and the ability to control non-Victron loads and chargers with ATD (allow to discharge) and ATC (allow to charge) controls. For example, if you wanted a second alternator with an external alternator controller, the ATC line is handy for telling the alternator controller to reduce the field strength of the alternator to zero immediately upon loss of battery. This prevents alternator load dump, which can fry sensitive electronics. If you had a DC powered A/C unit, you might use the ATD line along with a Smart BatteryProtect device to disconnect the A/C unit when the batteries reach a low voltage to protect them from excessive drain.
Using an external BMS provides a lot of extra functionality but it also requires you know what you’re doing. If you are designing this on your own, I would recommend you either work with a Victron dealer who can help you with the design and wiring digrams or choose a battery with internal heating and communications. As @lxonline said, where you live would depend on the region in which you live.
OGPS
7
Today, you would use an external battery monitor such as a SmartShunt, BMV-712, etc. Victron has said they plan to offer Bluetooth data flow between the current SuperPacks and a Cerbo (it is not available now) and wired data offering in the future. Today, however, if you want battery heating and integration with a GX device then IMO the SuperPack is not a great choice. I look forward to the future product revisions for the SuperPack.
In which country do you live?
A SuperPack NG has heating, and with a SmartShunt it connects perfectly to a Cerbo.
OGPS
9
Yes, of course. Now imagine you have two or more SuperPacks in parallel and want to use the internal battery heaters. Their default is to only use charging energy to run the heaters. The shunt will see that energy going to the battery as charging current, when in heating mode that energy is only being used to run the heaters. That will cause the SOC reported by the shunt to be inaccurate? Do you understand?
The batteries can be configured to run the heaters in auto mode, which will consume energy from the batteries. But the shunt will still report inaccurate state of charge, but perhaps have less error.
The main advantage of a battery system with an external BMS is that you have uninterrupted power, but you do need to set up your system properly! Victron’s external BMS also supports parallel and series connections. If a fault occurs, it is relatively easy to take the faulty sensor module out of service and continue operating the system.
By contrast, conventional batteries would simply be switched off. This can be critical when you have certain critical loads and charging sources (the heating cannot cool down, and alternators produce overvoltage when the load is shed).
OGPS
12
Exactly.
Not yet they haven’t, but the 2027 models will be much better.
