Which modern solar panels for the Multi RS19 Solar?
Hello everyone,
I’ve been looking at the data sheet for the Multi RS 19 Solar, and the Impp (“maximum operating input current limit”) caught my eye. At 12 A, I think it’s very low for the modules commonly used nowadays.
When I search for 1762 x 1134 x 30 mm, I can only really find the TSM-xxxNEG9R.28 series. If I allow a bit of leeway with the exact dimensions, I can also find the REC Alpha Pure-RX.
Since we order in large batches that need to last us a while, this would severely limit our options and might even put us off the RS19 Solar. We won’t stock two different models, and we also have to consider other criteria, such as having just one compatible option.
My dream was a server rack system that we could preconfigure in the shop, or buy preconfigured. The RS19 Solar units are also quieter. Given these requirements, the RS19 Solar is off the table for me until it gets an upgrade—or am I simply wrong and have missed something obvious?
Thanks in advance
You’re not wrong and many of us feel the same way. Frankly, I don’t think Victron should do a large production run of these units and instead work on a MK2 version that has proper MPPTs. You can search the forums for more discussion on this.
We do the same with PV modules. We try to standardize on one size for residential, C&I, and large trailer work so we can stock them. The 450W Philadelphia Solar modules we use have an Isc=14.47A.
What are the specs for these modules?
Could you attach a datasheet as well, please?
Most new high-efficiency panels this standard size (e.g. Aiko 500W, 6x9=54 cells) have Isc around 15A and Imp above 14A.
The REC Alpha (and TSM) are unusual in having more smaller cells in series, so higher voltage and lower current – but they’re also less efficient and more expensive… :frowning:
So yes, the Multi RS Solar is less than ideal nowadays… :wink:
I think Ian summed it up very well. I’ve attached the two datasheets as well.
At the moment, it seems quite clear that the Multi RS19 Solar isn’t really suitable for residential use. I’m still fairly new to the community: are there historical reasons for this? Is it simply an existing product in a new form factor? Or what application is the product intended for?
NEG9R.28_DE.pdf (1.8 MB)
DS_Alpha_Pure-RX_UL DC.pdf (826.7 KB)
This is a question you particularly ask yourself when considering 54/108-cell modules with an MPPT current of 14…15 A. Modern 108-cell modules with an area efficiency of >22% are already pushing the limits of an MPPT RS 450, which also has the additional drawback of a low string voltage of <450 V.
And what’s the problem with the panels mentioned there?
The datasheet shows an Impp of under 9A or just over 10A.
The Multi RS can handle a maximum of 3kW per tracker, so if you connect 7, 8 or 9 500W panels in series, you’ll probably hit the 3kW limit instead.
To exceed 12A at 3000W, the PV voltage would have to be below 250V.
Of course, it becomes problematic if you want to connect multiple strings in parallel to one tracker, but the devices simply aren’t designed for that.
The RS19 is just a Multi RS Solar in a 19" enclosure, so it has the same technology.
The Multi RS has been around since the end of 2021. I can’t say right now how much the datasheet has changed over the years, but there have been a few changes.
Hi Matthias, with the PV modules mentioned, it’s not a problem, but those are the only two series where that’s the case.
Examples where it doesn’t work are all the other PV modules rated at 450 W or higher.
Andy, that’s exactly how I understand it too. Thanks for the reply.
The 12A/16A limitation of the multi rs solar is a serious issue for professional installers. Yes you can work around the limitation by careful PV panel selection but with the other brands i don’t have to, i can just get the cheaper, more efficient panels. This drives up the system cost and limits options.
Also in the future the low string voltage and current will complicate retrofits.
Let’s hope they release a new/revised model.
Hello, you can look at the Trina Solar Vertex S+ serie. Between 450w et 470w, they are high voltage and low current. I think the 470w model has only 11A isc and high voltage of 55v voc. They are good but cheap panels and probably the most suitable for multi rs solar in the high power range.
I have the multi rs solar. My panels are isc ~14.2A and impp ~13.5A, but I hit the power limit of the mppts (3000w each) before i hit the amp limit of 12A, even in summer. This is because i have long strings of 8 panels in series, so around 265v strings at the minimum in summer when they are the hottest
Those Trina panels have similar voltage and current (>14A, too much for the Multi RS Solar) to all the other 56-cell ones, according to the data sheet.
These voltage/current ratings (and panel size) are the “industry standard” which almost all manufacturers use, great for customers because they can choose whatever is cheapest and easily available at the time of build – and easy to replace later if damaged.
There are a few suppliers with “special” size/voltage/current panels, but then you’re locked in with these – having a non-standard size could be a particular problem if a damaged panel ever has to be replaced.
It doesn’t seem a good idea to me to have a product which forces you to choose these “special” panels instead of any of the “standard” ones… :frowning:
The Trina Solar vertex s+ serie has models with high current panels but also models with low current panels.
For exemple, this one: Trina Vertex S+ 465W Dual Glass Black White N-Type Mono (Traceable)
As you can see the current is low and voltage is high
I agree that multi rs should have higher isc and impp. Victron needs to update this inverter mppts in futur revisions. I hope they understand this.
Yes, the Vertex S+ series has suitable modules, which is why I already mentioned the TSM-NEG9R.28, which also falls into that category (see datasheet above). But your answer misses the point: this isn’t about there being a single compatible module, but about the large number of modules that aren’t compatible.
We agree on the conclusion again: the product isn’t really useful for us as it stands. What a shame!
Same problem of needing “special” panels – I also note these are less efficient, are they older models?
It looks like the Multi RS Solar was designed (released end of 2021 – so probably in 2020?) when panel outputs (especially current) were lower than they are today.
Victron started working on the multi rs in 2019 if i recall.
Victron needs to improve the multi rs. A more powerful inverter (8000va) + bigger mppts (2x4000w with higher current input) would be perfect and would be a best seller for residential. I hope Victron will go this way.
Because i can tell you that this all in one inverter is incredible and vastly superior to other all in one inverter brands in almost all metrics
Too bad: the multi rs solar has got actually a double 4kw mppt…Because the fets of the mppt and the inverter are stuck on the same heat sink,the mppt side has been reduced to a double 3kw.(max of 6kw together instead of 8kw):enraged_face::weary_face::cry:
Having said this,I am using 9 x LG 400W bifacials on one string and 7 PEIMAR 595w bifacials on the other.The Peimar panels have got as base rated an IMP of 13.38 A and a ISC of 14.13 A.So both strings slightly over calculated.Never had any problems,though because the string Voltage is between 350V and 420V respectively .I am off grid and the multi rs solar works for me.I do understand,that for many projects,this wouldn’t be appropriate​:scream:
Maybe it’s just me, but I don’t understand your problem.
See my calculation example above: the 12A only really become relevant if you go below 250V PV voltage; above 250V, the tracker limits output to 3kW.
So if you make full use of the MPPT’s maximum PV voltage by putting the appropriate number of modules in series, and allow for 30% oversizing, the 12A should never be a problem.
It’ll only be an issue with very short strings below 250V, but in that case you’d be more likely to go for the 250V MPPTs, which have a much higher current limit.
Show us a datasheet for modules where you expect the 12A to be a problem.
I think there shouldn’t be any problems with a properly designed system.
These are what’s currently in stock where i buy my equipment, only the vertex 470WP is below 12A. I understand you can design a system with those panels, nobody says you cant connect panels to the multi rs solar.
You can’t deny however this severely limits the options i can offer customers, i can’t offer the cheapest per WP modules and i can’t offer the most efficient modules. I can’t use the modules that would allow for best placement on the roof. I can’t offer modules that have better shadow management. I can’t retrofit the multi rs solar if current modules are more recent than 2-4 years in most cases. It’s just annoying from a sales perspective.
But the current limits are soft ones assuming you dont connect in reverse polarity and the relatively small 3kW per tracker limit kicks in well before any throttling of excess current assuming strings in the 300V range, so you’d be at say 10A of PV input?
