As in the title when I look at my watch it is showing a value under AC loads. This value is actually my DC loads as the inverter is turned off and there are no AC loads. This has been going on for days.
But it works fine with the inverter on?
The system is designed around an operational vebus inverter (or similar). If this is not on then it will not behave as expected.
I will ask if something can be done about this.
